CUCM 10.5 as Video Call Processing Agent
mesut ozcan
Dear all,
Can you please share your experiences for using CUCM 10.5 as video call processing agent?
For example, registering VC endpoints to CUCM as SIP, registering MCU and TCS to CUCM exc.
Is it possible to register MCU and TCS to CUCM 10.5?
What is the cons and pros using CUCM 10.5 as call processing agent for VC endpoints instead of VCS Control?
Best Regards,
Mesut
Anas Abueideh
Level 9
Level 9
you need to unify and centralize your calling processing as much as you can.
when you have CUCM, it is prefered to use a Callling processing. use VCS for legacy endpoints and another integration, like traversal.
MCU can be registered to call manager.
When you have CUCM, you don't have license for the sessions
Anas
don't forget to rate the helpful posts
Do you have any guide about registering MCU and TCS to CUCM?
Best Regards,
Mesut
kindly find the deployment guide for MCU with CUCM
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/mcu/install_guide/Cisco_TelePresence_MCU_Deployment_guide_1-31.pdf
for TCS I can't find one
Anas
