CUCM 7.1 sip to Tandberg MXP 3000
r.robins
Hi All,
Does anybody have any pointers on getting a CUCM 7.1 cluster talking to a Tandberg MXP 3000 via SIP.
We have separate ISDN Bri for our Tandberg and want to get rid of them and pass voice only calls via call manager and a 2821 gateway router with 2 PRI's.
Any pointers would be real helpful.
thisisshanky
Level 11
Level 11
Check the Tandberg MXP3000 admin guide..
http://www.tandberg.com/support/video-conferencing-documentation.jsp?selProducts=&selProductType=17&selDocumentType=&selDisplayType=1&SearchButton.x=74&SearchButton.y=13
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Marwan ALshawi
yes you can
just setup a SIP trunk or H323 ICT trunk with the CUCM
and make sure you have the right setup in VCS and CUCM interns of SIP uri, or H323 ID
and in CUCM make sure you setup the right, regions/codec, locations, and CSS
also by using search rules and transformations in VCS you can control which call to send to CUCM ( for example on PSTN calls )
you can test it before you remove the existing PSTN lines ( recommended )
good luck
