06-26-2011 12:34 PM - edited 03-17-2019 10:21 PM
Hi All,
Does anybody have any pointers on getting a CUCM 7.1 cluster talking to a Tandberg MXP 3000 via SIP.
We have separate ISDN Bri for our Tandberg and want to get rid of them and pass voice only calls via call manager and a 2821 gateway router with 2 PRI's.
Any pointers would be real helpful.
06-27-2011 09:38 AM
Check the Tandberg MXP3000 admin guide..
06-28-2011 09:11 PM
yes you can
just setup a SIP trunk or H323 ICT trunk with the CUCM
and make sure you have the right setup in VCS and CUCM interns of SIP uri, or H323 ID
and in CUCM make sure you setup the right, regions/codec, locations, and CSS
also by using search rules and transformations in VCS you can control which call to send to CUCM ( for example on PSTN calls )
you can test it before you remove the existing PSTN lines ( recommended )
good luck
