CUCM Device Mobilty
I have a device mobility enabled, the devices all get the correct Device pool,location, region etc... when roaming, but the device calling search space.  The device always gets the configured CSS from the home device pool.  I have set the devices to <none> and still no change.  I move the phone to different networks, and the phone picks up the correct device pool, but the device CSS stays the same.
Any Ideas?
CUCM version 10.5.2
Zeke
5 Replies 5
Jaime Valencia
Are you roaming to another location, in the same device mobility group??
Or another location in a different device mobility group??
java
if this helps, please rate
Tried both...  different locations within the same group, and different groups.
added screen shots of configuration.
Have you assigned Device Mobility Group to home location' Device Pool as well (if u are using same device mobility group) ?
Suresh
Yes.  Also created a default device pool with a default device mobility group.
