06-21-2013 11:38 PM - edited 03-18-2019 01:20 AM
Hi Team
I have a question about that how can i config the bindwith for the siptrunk?
I used a sip tunk to let the cucm route the video call to the confrence in mcu(5310),but no matter how i set up the video bindwith of location profile in cucm, the transmit call rate just 384k,but the receive call rate is 4000k, but the call rate and resolution are fine when the mcu call the codec(C60) directly by using H.323.
i think that i miss someting in cucm configuration.
Solved! Go to Solution.
06-21-2013 11:57 PM
Hi Jason,
Could you provide more information about CUCM configuration? How are your regions configured? Do you have regions applied to SIP Trunk and to the device phone? Does the relation between the regions allow bandwidth enough for video?
If I am not wrong, the default bandwidth for video within region configuration is 384k. Did you change this value to your regions?
I would also suggest to review your location configuration and check if there is any limitation applied.
Paulo Souza
Please rate replies and mark question as "answered" if applicable.
06-21-2013 11:57 PM
Hi Jason,
Paulo Souza
06-22-2013 12:11 AM
Hi Paulo
Very thank you about that! i can't edit the region.
06-22-2013 12:22 AM
Hi Jason,
Are you saying that you cannot edit regions? Sorry, but I didn't understand your reply. As you mark the "right answer", I guess the problem was resolved by changing region configuration, right?
Paulo Souza
