08-21-2012 07:49 AM - edited 03-17-2019 11:38 PM
CUCM 8.6.2
I've got the Cisco VPN phone feature working with username/password. Interested in requiring the certificate as well.
If we want to require certificate plus username/password - what do we select in the VPN Profile Configuration section of Advanced features:
Username and Password
Password Only
Certificate
Where is the Certificate + xxxx ??
Also, the deployment guide states we should create a username and password like:
CP-7945G-SEPxxxxxxxx
We are currently using the LDAP integrated username / password and want to continue to do so. Is this possible?
Brian
08-22-2012 08:22 PM
I'm afraid those are the only options, there is no cert + something else option. Either there is user involvement on the first couple of options or there isn't with the cert option.
Also, please p,out in the right section, this one is for video over ip questions
10-28-2012 03:19 PM
Hello gentlemen,
I am taking activating a Phone VPN Feature, we using LDAP authentication on Cisco ASA, but in a IP Phone CP-7942 remotely while a wrote a username and password, we receive a message: User and password failed, but using a CiscoAnyConnect in a my notebbok login is a successfull.
Other question is: When I am with a ip phone remotely, I need disable a DHCP and edit TFTP-Server to CUCM IP Server corretly ?
Can you help-me in a deployment?
Best Regards,
Cláudio Costa
10-28-2012 05:07 PM
Claudio,
Stepping back for a second - the 7942 isn't supported according to most documentation I've seen.
Skip
