Custom Touch 10 User Interface Panels Not Clearing
tylehall1
We have a few custom UI panels that call Macros or trigger events with a control system, and I am struggling to find a way to clear the screen once the events occur. The main example is we have a feature to report a room issue to the support team, but once it is sent, the Report Issue panel remains on the screen.
Is there a command I can send to clear the UserInterface Extensions Panel from the screen (the Command UserInterface Extensions Panel Clear deletes the panel but an empty panel remains on the screen), alternatively, is there a way to set a timeout on the panel so that it only stays up for 20 seconds or so? Perhaps similar to how you can hide row labels on the panels
0 Replies 0
