Dial-pattern problem.
admin_2
Level 3
Level 3
As I can lower the time that is delayed in dialing when I have symbol T in destination pattern.
dial-peer voice 1 pots
trunkgroup fxos
description anexos-locales
destination-pattern 1..T
no digit-strip
dial-peer voice 10 pots
trunkgroup fxos
description local
destination-pattern 9.....T
no digit-strip
dial-peer voice 20 pots
trunkgroup fxos
description LLamados LDN
destination-pattern .....90[1-7].......
no digit-strip
prefix **
Thanks.
Tony Huynh
Level 4
Level 4
If you are using CME, you can use the following command underneath telephony-service:
router(config-telephony)#timeouts interdigit ?
<2-120> seconds
If you have a regular h323 gateway, you need to use the following command underneatht he voice-port that is being used to dial outbound:
router(config-voiceport)#timeouts ?
call-disconnect Call Disconnect Timeout after Destination Hangs Up in seconds
initial Initial Timeout duration in seconds
interdigit Interdigit Timeout duration in seconds
ringing Ringing no answer timeout duration in seconds
wait-release Wait release timeout duration in seconds
router(config-voiceport)#timeouts interdigit ?
<0-120> seconds
This should resolve your issue.
Tony
omarabdallah
Hello
To lower the time taken by symbol T which is by default 10 seconds
use commande "timeouts interdigit" the value is in seconds.
Take care that this also will affect the timing when the user is dialing the normal numbers.
Omar
heathrw
Level 4
Level 4
This maybe off subject but interested to know if your trunk group allocation works? would like to confirm they are FXO ports. Im wanting to achive the same thing using ISDN BRI. Conversation name
