11-22-2010 03:15 PM - edited 03-17-2019 10:09 PM
I'm trying to exchange calls between 2 SIP proxies and and a cisco gateway (AS5300)
Let me first show you what what I'm trying to accomplish before I explain my problem
SIP_Proxy_1<--->AS5300<-->SIP_Proxy_2
PSTN
Calls are sent from proxy 1 to proxy 2 with prefix 2222
Calls are sent from proxy 2 to proxy 1 with prefix 1111
Proxy 1 and proxy 2 calls out to PSTN through the gateway with prefix 9999
proxy 1 and proxy 2 do NOT dial fixed length digits after the prefix, it always varies.
here are my dial peers settings:
dial-peer voice 1111 voip
destination-pattern 1111T
voice-class codec 10
session protocol sipv2
session target ipv4:192.168.1.1
dtmf-relay rtp-nte
no vad
dial-peer voice 2222 voip
destination-pattern 2222T
session target ipv4:192.168.1.2
dtmf-relay rtp-nte
no vad
dial-peer voice 100 pots
destination-pattern 9999T
no digit-strip
direct-inward-dial
port 0:D
I'm sure I have Dial-peers not configured right but I cannot figure it out.
when SIP proxy 1 calls exten 2222175 at proxy 2 going through the AS5300, the AS5300 returns (SIP/2.0 404 Not Found). Any guidance on how I can accomplish this task is really appreciated, I'm no cisco guy but I'm under so much pressure
Dave,
11-23-2010 12:00 PM
Hi Dave,
The dialpeers look correct. Although we need incoming peers too. For example:
dial-peer voice 100 voip
incoming called-number .
codec xx
Understanding Inbound and Outbound Dial Peers Matching:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
When you call through the Access server like this it will be an IPIP call. Make sure you have:
voice service voip
allow-connection sip to sip
configure. And also I would not use voice class codec. It is not supported with IPIP gateway below the version 15.1(2)T. It might lead to codec mismatch. If after adding the commands which I have suggested the calls still does not work please collect:
debug ccsip messages
debug voice ccapi inout
from the AS5300 along with the dialpeer configuration.
Best regards,
Apor
