dial-peer voice voip
Wai wai
Dear expects,
Currenly I have a Router act as a voice gateway between phone systems and I found a lot of dial peer voice voip configuration in the Router, may I know if there is any limitattion or maximum total numbers of dial-peer voice voip configration that I can create in a Router ? because I would like to add 50+ more entry of dial peer voice voip configuration to the Router but not sure whether the Router can still support it or not, I don't want to heavily utilize and burdening the load of this Router
Sorry for my bad english and thanks in advance
ronpatel
Level 8
Level 8
Practically we do not have limit. On my router I can configure 1-1073741823 dial peers which are much beyond the required by any deployment.
regards
Ronak patel
Rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
The number of dial-peers you can configure is mainly limited by the amount of RAM in the router.  Here's how you can calculate how many you can configure: https://supportforums.cisco.com/docs/DOC-3206
