Digital Signage Templates
kyle.king
We just received two 4305G Digital Media Players. We have no backend server or streaming server or anything like that. We're a fairly small shop so we don't have anyone particularly gifted in HTML.
Does anyone know of a place to find some templates or a WYSIWYG editor so I can create some Digital Signage pages for these devices to display? Or would it be better to go ahead and purchase the backend management server. If we do get cisco's management server, does that include any kind of signage editor or will we still need to develop the sites ourselves?
Thanks for the help!
smalkeric
Level 6
Level 6
You can generate pdf files from the nroff source and use Acrobat to edit it
"nroff" source? I don't think I follow. Could you explain a little more?
The Digital Media Manager does have software that allows you to create the Signage content.
Is that a separate product? With a separate cost?
