Direct-manage by TMS
Xiangzhen Quan
Hi experts
How many system/device can be managed by TMS?
In datesheet and other documents, it says 5000.
But we can only add it up to 2000 in CCW.
Which is correct?
QxiangZh
7 Replies 7
mahkrish
Level 3
Level 3
Hi Quan, Can you please provide more inputs for the below ?
1. What is your TMS installed software version ? Are you using SQL express or SQL standard[External database server] ?
2. What is the total number of system option keys added in TMS --> Administrative Tools --> Configuration --> General Settings -->Option Keys ?
3. Can you share the steps and type of end points you are adding in TMS ?
BR, Mahesh Adithiyha
Hi mahkrish
Thanks for you quick response.
Please refer the following screenshoot:
About your question, I don't know the information so far.
The issue is happened when the partner create the BOM for customer.
I just want to confirm maximum number of the devices that can be direct-managed by TMS.
2000? or 5000?
Thanks very much
Quan
Hello Mahkrish
Any suggestion please?
Hi Quan,
I have sent you an e-mail with the respective contact. Please check with them.
Thanks for you suggestion~
Sumeet Rakesh
Adding systems in TMS depends upon the number of license you have. As per the screenshot you have license for 2125 systems approx. Moreover your database should also support such large number of managed devices so it will be better if you have SQL enterprise version together with license for all 5000 systems.
Sumeet Rakesh
Hello
But where should I choose another 3000 licenses??
Thanks!
