03-04-2015 07:42 AM - edited 03-18-2019 04:08 AM
I have a Cisco C20 that I am going to setup. I am getting ready to purchase the displays and looking for the requirements.
HDMI is all I need right? I just do not want to make some kind of rookie mistake.
Any special HDMI cables?
Thank you for your time.
Solved! Go to Solution.
03-04-2015 09:10 AM
Thanks Yusuke, I was thinking 10-15, but wasn't sure at the time and didn't want to give a wrong number because I wasn't able to look it up.
03-04-2015 08:35 AM
Do you mean SX20? C20 has been end of sale for a few years by now. It's been awhile since we've purchased a new codec, but it does come with some HDMI cables, don't recall the length though.
03-04-2015 08:38 AM
Yes, it is a new old stock C20. We have two in stock because of a reduction in force.
03-04-2015 09:08 AM
Hi Manticore,
C20 video output is HDMI. No special HDMI cable is needed. Just a good quality category 2 cable is required.
See the following Admin Guide; page 132
Hi Patrick,
The maximum length is 50ft/15meters.
Refer the knowledgebase document below; page 11
Yusuke
03-04-2015 09:10 AM
03-04-2015 09:09 AM
Gotcha, for some reason I read it as you were purchasing the codecs too. Nothing special is needed in regards to the HDMI cables. You'll also need a VGA to DVI cable with audio if you'd like to share content from a PC or laptop.
03-04-2015 09:50 AM
Thank you Patrick and Yusuke for the quick and informative responses! This information has been VERY helpful.
I tried to best answer you both but I am not sure if it took.
-Matt
