Display requirements for Cisco C20
Manticore
I have a Cisco C20 that I am going to setup.  I am getting ready to purchase the displays and looking for the requirements.
HDMI is all I need right?  I just do not want to make some kind of rookie mistake.
Any special HDMI cables?
Thank you for your time.
Thanks Yusuke, I was thinking 10-15, but wasn't sure at the time and didn't want to give a wrong number because I wasn't able to look it up.
6 Replies 6
Patrick Sparkman
Do you mean SX20?  C20 has been end of sale for a few years by now.  It's been awhile since we've purchased a new codec, but it does come with some HDMI cables, don't recall the length though.
Yes, it is a new old stock C20.   We have two in stock because of a reduction in force.
Hi Manticore,
C20 video output is HDMI. No special HDMI cable is needed. Just a good quality category 2 cable is required.
See the following Admin Guide; page 132
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/codec-c-series/tc7/administration-guide/profile-c20-and-quickset-c20-administrator-guide-tc73.pdf
Hi Patrick,
The maximum length is 50ft/15meters.
Refer the knowledgebase document below; page 11
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/articles_doc/telepresence_endpoints_knowledge_base_articles.pdf
Yusuke
Gotcha, for some reason I read it as you were purchasing the codecs too.  Nothing special is needed in regards to the HDMI cables.  You'll also need a VGA to DVI cable with audio if you'd like to share content from a PC or laptop.
Manticore
Thank you Patrick and Yusuke for the quick and informative responses!  This information has been VERY helpful.
I tried to best answer you both but I am not sure if it took.
-Matt
