Distance learning and mpeg video
I have a customer that is looking for a solution to a distance learning problem. The essential part of the problem is that he has an ATM cloud that has video equipment connected to it that is working just fine. He now wants to be able to expand this to an arbitrary IP endpoints.
I am thinking that with the deployment of a 354x server to act as the gateway/gatekeeper, that the endpoints can register to the gatekeeper and then have dynamic conferences defined to connect endpoints to.
I have looked at the documentation and it does not look like the systems will support mpeg1 or mpeg2 streams.
Anyone know if it does or will support mpeg2?
Thanks.
sbilgi
Level 5
Level 5
