09-17-2017 05:04 PM - edited 03-18-2019 01:28 PM
Hi ,
I have one single combined CMS and would like to have another one. Then I will have two Single Combined servers. If I deploy them all in the Internal network rather than DMZ, I need to have Collab-edge server which I don't know if it requires any licenses. Are two single combined servers in Internal and one Edge able to support CMA and WebCRT through the Internet?
Solved! Go to Solution.
09-17-2017 08:15 PM - edited 09-17-2017 08:17 PM
Most of the CMS components themselves don't require a license, but they do require an activated Call Bridge. If you check the CMS Configuration Guides, they cover what components require a license and what requires an activated Call Bridge.
09-17-2017 07:20 PM
You can deploy CMS core in internal network and put CMS edge in DMZ. CMS edge requires no license.CMS requires license for callbridge, branding, recording and streaming only. However, you do need a activated callbrigde in order to deploy XMPP.
You can also put a single combine CMS in internal network, and use expressway-E as the edge sitting in the DMZ.(This is cisco recommended deployment)
09-17-2017 07:31 PM
