04-06-2017 07:30 AM - edited 03-18-2019 12:58 PM
I have Cisco video telepresence system with endpoint registered to CUCM. With MRA, you can have IP phone deskphone and DX series endpoint registered to CUCM using MRA externally. I have C20, SX20, C40 and C60 codec and MXP95 thirdparty endpoint regsitered to CUCM. Can I registered this endpoints in CUCM from external network. With newer endpoints you can have cloud capability. If yes, how can I registered to CUCM from external network?
04-06-2017 08:13 AM
You can register TC and CE based endpoints to CUCM through MRA, however the MXP and thrid-party systems aren't supported. Take a look at the Collaboration Edge TC-based Endpoints Configuration Example, for CE based endpoints the process is the same. For the most up to date list of endpoints that support MRA, refer to the Expressway Data Sheet.
04-06-2017 08:14 AM
Thank you. I have another question regarding registering TC/CE based endpoint to internet. e.g. If I get IP address and access to internet when I take this endpoint to external network. I know SX10/20 had that capability where you can get IP address and access to internet and you can dial any SIP URI to make call. You do not need any call control to register codec. Is that something available with TC/CE endpoints.
04-06-2017 08:20 AM
You can configure the endpoint to be standalone, which isn't registered to any call control server such as CUCM. For the required configuration that has to be done on the endpoint and firewall. take a look at Vivek's post here: sx20-standalone.
