Showing results forĀ
Search instead forĀ
Did you mean:Ā
Doubt about "SX20 - View dialing method"
jmhalegre
Hi Team,
Our customer has recently updated the Ciso Telepresence SX20 from version TC7.1.1 to version CE9.5.2.
They indicate us that now, when they are going to make a call, the "View dialing method" option does not appear.
This is due to the change of TC software to CE software?
What alternative does the client have?
Thanks & Best Regards,
JuanMi
I have just replicated the bahaviour in the latest CE9 releases, and can confirm that the option is only present on the web interface, and not on the Touch10 or via the remote.
You can however put a "sip:" or a "h323:" in front of the address you want to dial to use a specific protocol.
If you're consistently having to do this for a specific address, I'd recommend that you add it to the directory rather than having to have your users specify it on each occasion, and that way you can also give it a name that may easier for people to identify rather than a set of numbers (Ie "Fred's Office" rather than "h323:123.123.123.124").
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Firstly, are you using a Touch10, or are you using a Remote?  And what are you referring to as the "dialling method"?  But in an attempt to answer your quesiton, if you are using a Touch10, you can go to the "... / More" button, and then click on Call rate, where you can swtich the call to an Audio only call (assuming that is what you were asking)?
Wayne
Hi Wayne,
When the customer makes a new call from the remote control, depending on the version, the following happens:
  • From software version TC7.1.1 - The option to select the protocol to use "H.323/SIP" appears.TC7.1.1.png
  • From software version CE9.5.2 - The option to select the protocol to use "H323/SIP" does not appear.
From the CE version, the only way to indicate the protocol is from the GUI "Call Control", editing the call as shown below, it is right?Call Control.png
Summarizing, when we make a new call from the remote control with the CE software version , is it possible to select the protocol to use "H.323/SIP"? Or the only way is via GUI "Call Control"?
Juan Miguel Huertas Alegre
Wayne
Hi Wayne,
Thanks for confirmation.
Best Regards,
JuanMi
