08-22-2014 11:57 PM - edited 03-18-2019 03:19 AM
I am able to make calls in to my CUE but I cant enter my pin. It acts like its not getting any button presses. I assume there is something wrong with my DTMF relay. Here is the sho run of the realavent parts:
voice service voip
ip address trusted list
ipv4 10.1.5.2 255.255.255.255
ipv4 10.1.5.3 255.255.255.255
ipv4 10.1.6.3 255.255.255.255
ipv4 10.1.6.2 255.255.255.255
ipv4 10.1.7.2 255.255.255.255
ipv4 10.1.131.1 255.255.255.255
ipv4 10.1.131.2 255.255.255.255
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/1
bind media source-interface GigabitEthernet0/1
registrar server
voice register global
mode cme
max-dn 4
max-pool 4
load 7961 SIP41.9-1-1SR1S.loads
load 7941 SIP41.9-1-1SR1S.loads
timezone 22
voicemail 4500
tftp-path flash:
create profile sync 0011101915212849
voice register dn 1
number 4001
call-forward b2bua busy 4500
call-forward b2bua noan 4500 timeout 10
name Peter Brown
label Peter Brown
mwi
voice register pool 1
id mac 001F.CA35.0A91
type 7961
number 1 dn 1
codec g711ulaw
dial-peer voice 4500 voip
destination-pattern 450[01]
session protocol sipv2
session target ipv4:10.1.130.2
dtmf-relay sip-notify
codec g711ulaw
no vad
sip-ua
mwi-server ipv4:10.1.130.2 expires 3600 port 5060 transport udp
interface Integrated-Service-Engine1/0
ip unnumbered GigabitEthernet0/1
service-module ip address 10.1.130.2 255.255.255.0
!Application: CUE Running on NME
service-module ip default-gateway 10.1.130.1
no keepalive
Solved! Go to Solution.
08-23-2014 07:36 AM
First, I would check your CUE configuration to verify the DTMF method you have provisioned there. Session to the NME and execute the command:
show ccn subsystem sip
Make sure the DTMF method reported by CUE matches the voip dial-peer you have pointing to CUE.
Next, I would also specify the same DTMF method under the "voice register pool 1" configuration stanza.
HTH.
-Bill (@ucguerrilla)
http://ucguerrilla.com
08-23-2014 07:36 AM
HTH.
08-25-2014 05:42 PM
I ended up calling TAC. The fix ended up being setting everything to "rtp-ne".
