12-05-2012 08:17 PM - edited 03-18-2019 12:15 AM
Hi, Experts
We have an situation, when customer A's Movi call customer B'2 TP server, everything works fine, but the application/desktop sharing is not work, I just want to know is there any specific settings for that to work?
So far there's only DNS zone and DNS search rule to make the B2B calls works, I'm not sure if there are any other settings to make the BFCP or dual stream work?
12-06-2012 04:33 PM
Works fine here, computer movi from and to TPS (at least within our organization), but b2b should behave the same.
The iPad client only shows one stream with the content above the participant strip.
12-06-2012 06:54 PM
Then it's weird here, my Movi called another company's TPS which setup an meeting id like XXXXXXX@abc.com, I could dial-in, but the application sharing can not be viewed by other participants...
12-09-2012 06:23 PM
Hi, Martin
I found if I trying to call the MCU by xxx@jabber.com, the dual stream works, but if it's calling from my Movi under the VCS Control or VCS Exprewssway, the dual stream didn't works, any specific reason for this?
