12-17-2018 03:49 PM - edited 03-18-2019 02:31 PM
Does the DX80 supports any USB microphones? I have a customer who wants connect an external microphone to a DX80 because he wants to be able to mute the mic without having to sit within arms reach of the integrated mute button. I don't think the TRC6 remote is compatible with the DX80 for muting either.
12-17-2018 04:58 PM - edited 12-17-2018 05:02 PM
There isn't any specificly supported microphone. If the microphone supportes the HID protocol, then it should work. See this document https://collaborationhelp.cisco.com/article/en-us/nkiifbo - while it refers to USB headsets, the same should apply for a microphone.
If you end user is getting too far away from the device, then that may defeat the purpose of using a desktop based unit, and perhaps a different model endpoint would be a better choice?
Please remember to mark helpful responses and to set your question as answered if appropriate.
08-20-2020 12:06 PM
Is it compatible with the Cisco table microphone?
08-23-2020 07:43 PM
No.
12-19-2018 09:15 AM
We used Polycom VoxBox microphones connected to DX80.
04-15-2019 03:17 AM
On DX80 site, is it needed a bluetooth USB dongle ? Or it's included with VoxBox ? Thhanks
04-15-2019 03:18 AM
