DX80 set Static IP ,but after it restart it change to dhcp
CN_donke.xu
Hello Friends
I had a problem about DX80,I set Static IP for it ,but  after it restart it change to dhcp.What's the problem
Thanks&Best Regards
Donke xu
Aman Soi
I am also facing the same issue using CUCM 10.5 and DX version is DX80 version is sipdx80.10.2.4.46.
Android version is 4.1.1
I do not know whether this bug is related to our issue . What is the firmware version and CUCM version u are using?
IPv4 Configuration disappears after upgrading firmware
CSCux14111
Description
Symptom:
Conditions:
ANDROID version
Workaround:
No workaround
Further Problem Description:
IP default configuration is "USE static IP" unchecked. Also when going to different versions of ANDROID there is always a Factory Reset done by DX itself. (Not by user.) That is why IPv4 Configuration disappears.
Known Affected Releases:
(1)
10.2(4)
regds,
aman
Thanks aman
So this is a bug ,we can't slove this problem now .
