Hi!
I encountered a problem yesterday that I just couldn't get my head around.
A Movi/jabber user tried to place a call to a Edge 95 MXP, the call got connected got disconnected directly due to encryption mismatch.
The setting in the Edge-system was set to auto. Doesn't this mean that it won't try to encrypt the call if it doesn't work?
When I set the seting to off it worked just fine.
Thank you in advance!
