Endpoint Configuration Changing
Let me start by saying I'm new to VTC in every way, but somehow I was lucky enough to have this system land in my lap.  I've learned quite a bit about it, and have most of my configurations under control.  Currently I have about 25 endpoints (EX90, SX20, C40) running TC7.2.1 connecting to TMS version 14.0.0, although it appears it should 14.x as I don't even see 14.0 listed in the software.
I have it set up now so TMS pushes out the configuration template I built to the systems daily at 0300.  I am not using provisioning.  When I check the configuration template activity status, it shows the template was successful.  It also runs an update 0200 daily from tmsservice with the description "Templates - Update systems with persistent settings only".  It says that is successful as well, but shows that it didn't update any systems, as it shouldn't.  I assumed that was causing the issue, which is why I set mine to run at 0300 to override those settings.  If I run my template at anytime, it will update the systems with the correct settings.  However, they seem to keep reverting back seemingly on their own.  The main setting that changes is the Provisioning, External Manager, Protocol.  I need it to be HTTPS, and that's what gets pushed to it.  But it will revert back to HTTP.  I attached the log file from a unit below.  I'm thinking I'm just missing something, but any help would be much appreciated.
Also, not a huge issue, but just another thing I can't get working.  I was trying to have TMS send out software updates to the units, but that didn't appear to work either.  It was a little bit ago that I tried, so I don't recall the exact error or have any log files.  Just wasn't sure if it was a common issue.
Thanks for the help.
Sep  9 03:00:34.803 a8 appl[1712]: 591566.92 CuilApp   User admin(1001) successfully changed configuration 'Config/Conference[1]/AutoAnswer[1]/Mode[1]' to 'Off' from 10.3.1.212.
Sep  9 03:00:34.813 a8 appl[1712]: 591566.93 CuilApp   User admin(1001) successfully changed configuration 'Config/H323[1]/Profile[1]/PortAllocation[1]' to 'Dynamic' from 10.3.1.212.
Sep  9 03:00:34.891 a8 appl[1712]: 591567.01 CuilApp   User admin(1001) successfully changed configuration 'Config/H323[1]/Profile[1]/CallSetup[1]/Mode[1]' to 'Gatekeeper' from 10.3.1.212.
Sep  9 03:00:34.898 a8 appl[1712]: 591567.01 CuilApp   User admin(1001) successfully changed configuration 'Config/H323[1]/Profile[1]/Gatekeeper[1]/Address[1]' to 'MEADTICAFNETVCSC.XXX' from 10.3.1.212.
Sep  9 03:00:34.945 a8 appl[1712]: 591567.06 CuilApp   User admin(1001) successfully changed configuration 'Config/H323[1]/Profile[1]/Gatekeeper[1]/Discovery[1]' to 'Manual' from 10.3.1.212.
Sep  9 03:00:34.953 a8 appl[1712]: 591567.07 CuilApp   User admin(1001) successfully changed configuration 'Config/H323[1]/Profile[1]/Authentication[1]/Password[1]' to '*hidden*' from 10.3.1.212.
Sep  9 03:00:34.994 a8 appl[1712]: 591567.11 CuilApp   User admin(1001) successfully changed configuration 'Config/H323[1]/Profile[1]/Authentication[1]/Mode[1]' to 'On' from 10.3.1.212.
Sep  9 03:00:35.005 a8 appl[1712]: 591567.12 CuilApp   User admin(1001) successfully changed configuration 'Config/H323[1]/NAT[1]/Mode[1]' to 'Off' from 10.3.1.212.
Sep  9 03:00:35.046 a8 appl[1712]: 591567.16 CuilApp   User admin(1001) successfully changed configuration 'Config/Network[1]/Assignment[1]' to 'DHCP' from 10.3.1.212.
Sep  9 03:00:35.072 a8 appl[1712]: 591567.19 CuilApp   User admin(1001) successfully changed configuration 'Config/Network[1]/DNS[1]/Server[1]/Address[1]' to 'XXX.XXX.XXX.XXX' from 10.3.1.212.
Sep  9 03:00:35.095 a8 appl[1712]: 591567.21 CuilApp   User admin(1001) successfully changed configuration 'Config/Network[1]/DNS[1]/Server[2]/Address[1]' to 'XXX.XXX.XXX.XXX' from 10.3.1.212.
Sep  9 03:00:35.120 a8 appl[1712]: 591567.24 CuilApp   User admin(1001) successfully changed configuration 'Config/Network[1]/DNS[1]/Domain[1]/Name[1]' to 'XXX' from 10.3.1.212.
Sep  9 03:00:35.149 a8 appl[1712]: 591567.26 CuilApp   User admin(1001) successfully changed configuration 'Config/Network[1]/VLAN[1]/Voice[1]/Mode[1]' to 'Off' from 10.3.1.212.
Sep  9 03:00:35.160 a8 appl[1712]: 591567.27 CuilApp   User admin(1001) successfully changed configuration 'Config/Network[1]/IPStack[1]' to 'IPv4' from 10.3.1.212.
Sep  9 03:00:35.200 a8 appl[1712]: 591567.32 CuilApp   User admin(1001) successfully changed configuration 'Config/Network[1]/QoS[1]/Mode[1]' to 'Diffserv' from 10.3.1.212.
Sep  9 03:00:35.226 a8 appl[1712]: 591567.34 CuilApp   User admin(1001) successfully changed configuration 'Config/NetworkServices[1]/Telnet[1]/Mode[1]' to 'Off' from 10.3.1.212.
Sep  9 03:00:35.262 a8 appl[1712]: 591567.38 CuilApp   User admin(1001) successfully changed configuration 'Config/NetworkServices[1]/HTTP[1]/Mode[1]' to 'Off' from 10.3.1.212.
Sep  9 03:00:35.286 a8 appl[1712]: 591567.40 CuilApp   User admin(1001) successfully changed configuration 'Config/NetworkServices[1]/HTTPS[1]/Mode[1]' to 'On' from 10.3.1.212.
Sep  9 03:00:35.314 a8 appl[1712]: 591567.43 CuilApp   User admin(1001) successfully changed configuration 'Config/NetworkServices[1]/SNMP[1]/Mode[1]' to 'ReadOnly' from 10.3.1.212.
Sep  9 03:00:35.330 a8 appl[1712]: 591567.45 CuilApp   User admin(1001) successfully changed configuration 'Config/NetworkServices[1]/SNMP[1]/CommunityName[1]' to 'CAF_v2c' from 10.3.1.212.
Sep  9 03:00:35.370 a8 appl[1712]: 591567.49 CuilApp   User admin(1001) successfully changed configuration 'Config/NetworkServices[1]/SNMP[1]/Host[1]/Address[1]' to '10.3.1.212' from 10.3.1.212.
Sep  9 03:00:35.378 a8 appl[1712]: 591567.49 CuilApp   User admin(1001) successfully changed configuration 'Config/NetworkServices[1]/SNMP[1]/Host[2]/Address[1]' to '172.26.100.26' from 10.3.1.212.
Sep  9 03:00:35.427 a8 appl[1712]: 591567.54 CuilApp   User admin(1001) successfully changed configuration 'Config/NetworkServices[1]/SNMP[1]/Host[3]/Address[1]' to '172.26.100.27' from 10.3.1.212.
Sep  9 03:00:35.440 a8 appl[1712]: 591567.56 CuilApp   User admin(1001) successfully changed configuration 'Config/NetworkServices[1]/H323[1]/Mode[1]' to 'On' from 10.3.1.212.
Sep  9 03:00:35.478 a8 appl[1712]: 591567.59 CuilApp   User admin(1001) successfully changed configuration 'Config/NetworkServices[1]/SIP[1]/Mode[1]' to 'On' from 10.3.1.212.
Sep  9 03:00:35.485 a8 appl[1712]: 591567.60 CuilApp   User admin(1001) successfully changed configuration 'Config/NetworkServices[1]/NTP[1]/Mode[1]' to 'Manual' from 10.3.1.212.
Sep  9 03:00:35.524 a8 appl[1712]: 591567.64 CuilApp   User admin(1001) successfully changed configuration 'Config/NetworkServices[1]/NTP[1]/Address[1]' to '172.26.100.18' from 10.3.1.212.
Sep  9 03:00:35.548 a8 appl[1712]: 591567.66 CuilApp   User admin(1001) successfully changed configuration 'Config/Phonebook[1]/Server[1]/ID[1]' to 'MEADTICAFNET212.XXX' from 10.3.1.212.
Sep  9 03:00:35.554 a8 appl[1712]: 591567.67 MC ERROR: Mcfsm::TTPARParDistribute() unhandled state change, numRef=2
Sep  9 03:00:35.585 a8 appl[1712]: 591567.70 CuilApp   User admin(1001) successfully changed configuration 'Config/Phonebook[1]/Server[1]/URL[1]' to 'https://meadticafnet212.XXX/tms/public/external/phonebook/phonebookservice.asmx' from 10.3.1.212.
Sep  9 03:00:35.600 a8 appl[1712]: 591567.72 MC ERROR: Mcfsm::TTPARParDistribute() unhandled state change, numRef=2
Sep  9 03:00:35.605 a8 appl[1712]: 591567.72 CuilApp   User admin(1001) successfully changed configuration 'Config/Provisioning[1]/Mode[1]' to 'TMS' from 10.3.1.212.
Sep  9 03:00:35.649 a8 appl[1712]: 591567.76 MC ERROR: Mcfsm::TTPARParDistribute() unhandled state change, numRef=2
Sep  9 03:00:35.651 a8 appl[1712]: 591567.77 CuilApp   User admin(1001) successfully changed configuration 'Config/Provisioning[1]/ExternalManager[1]/Address[1]' to 'MEADTICAFNET212.XXX' from 10.3.1.212.
Sep  9 03:00:35.671 a8 appl[1712]: 591567.79 TMS I: provision(): http request url/http://MEADTICAFNET212.XXX/tms/public/external/management/systemmanagementservice.asmx/779 bytes
Sep  9 03:00:35.688 a8 appl[1712]: 591567.80 CuilApp   User admin(1001) successfully changed configuration 'Config/Provisioning[1]/ExternalManager[1]/Protocol[1]' to 'HTTPS' from 10.3.1.212.
Sep  9 03:00:35.694 a8 appl[1712]: 591567.81 MC ERROR: Mcfsm::TTPARParDistribute() unhandled state change, numRef=2
Sep  9 03:00:35.715 a8 appl[1712]: 591567.83 CuilApp   User admin(1001) successfully changed configuration 'Config/Provisioning[1]/ExternalManager[1]/Path[1]' to 'tms/public/external/management/systemmanagementservice.asmx' from 10.3.1.212.
Sep  9 03:00:35.732 a8 appl[1712]: 591567.85 CuilApp   User admin(1001) successfully changed configuration 'Config/Provisioning[1]/HttpMethod[1]' to 'POST' from 10.3.1.212.
Sep  9 03:00:35.765 a8 appl[1712]: 591567.88 CuilApp   User admin(1001) successfully changed configuration 'Config/SerialPort[1]/LoginRequired[1]' to 'On' from 10.3.1.212.
Sep  9 03:00:35.822 a8 appl[1712]: 591567.94 CuilApp   User admin(1001) successfully changed configuration 'Config/Time[1]/TimeFormat[1]' to '24H' from 10.3.1.212.
Sep  9 03:00:35.846 a8 appl[1712]: 591567.96 CuilApp   User admin(1001) successfully changed configuration 'Config/Time[1]/DateFormat[1]' to 'DD_MM_YY' from 10.3.1.212.
Sep  9 03:00:35.877 a8 appl[1712]: 591567.99 CuilApp   User admin(1001) successfully changed configuration 'Config/UserInterface[1]/UserPreferences[1]' to 'Off' from 10.3.1.212.
Sep  9 03:00:35.897 a8 appl[1712]: 591568.01 CuilApp   User admin(1001) successfully changed configuration 'Config/Security[1]/Session[1]/InactivityTimeout[1]' to '300' from 10.3.1.212.
Sep  9 03:00:35.935 a8 appl[1712]: 591568.05 CuilApp   User admin(1001) successfully changed configuration 'Config/Security[1]/Session[1]/ShowLastLogon[1]' to 'On' from 10.3.1.212.
Sep  9 03:00:36.171 a8 appl[1712]: 591568.29 TMS I: provision(): http request url/https://MEADTICAFNET212.XXX/tms/public/external/management/systemmanagementservice.asmx/779 bytes
Sep  9 03:00:37.564 a8 appl[1712]: 591569.68 CuilApp   User admin(1001) successfully changed configuration 'Config/Provisioning[1]/Mode[1]' to 'Tms' from 10.3.1.212.
Sep  9 03:00:38.362 a8 appl[1712]: 591570.48 CuilApp   User admin(1001) successfully changed configuration 'Config/Provisioning[1]/ExternalManager[1]/Address[1]' to 'MEADTICAFNET212.XXX' from 10.3.1.212.
Sep  9 03:00:39.035 a8 appl[1712]: 591571.15 CuilApp   User admin(1001) successfully changed configuration 'Config/Provisioning[1]/ExternalManager[1]/Path[1]' to 'tms/public/external/management/systemmanagementservice.asmx' from 10.3.1.212.
Sep  9 03:00:45.690 a8 appl[1712]: 591577.80 TMS ERROR: http(this=0x4456b9a0): failed with <Authentication fail> (HTTP code=403)
Sep  9 03:00:45.690 a8 appl[1712]: 591577.81 TMS I: provision(): tms query FAILED, length 1233
Sep  9 03:00:45.817 a8 appl[1712]: 591577.93 TMS I: provision(): tms query succeeded, length 1196
Sep  9 03:00:45.820 a8 appl[1712]: 591577.93 TMS I: executor(): Found heartbeat rate 0
Sep  9 03:00:45.825 a8 appl[1712]: 591577.94 CuilApp   User root(0) about to execute command '/HttpFeedback/Register Expression[1]: /History/CallLog/History Expression[2]: /History/CallLogs/Call Expression[3]: /Status/Call[Status='Connected'] Expression[4]: /Status/H323/Gatekeeper Expression[5]: /Status/SIP/Registration Expression[6]: /Status/Network/Ethernet/Speed Expression[7]: /Event/CallSuccessful Expression[8]: /Event/Message/Prompt/Response FeedbackSlot: 3 ServerUrl: http://meadticafnet212.XXX/tms/public/feedback/code.aspx'; from .
Sep  9 03:00:45.830 a8 appl[1712]: 591577.95 TMS I: executor(): cuil-processed buffer of 690 bytes
Sep  9 03:00:45.832 a8 appl[1712]: 591577.95 TMS I: provision(): ok ! heartbeat 0 ! upgrade no ! 0 files ! 0 docs
Sep  9 03:00:45.866 a8 appl[1712]: 591577.98 HTTPFB I: Queue::removeAllByCollectionId: 3
Sep  9 07:05:41.281 a8 appl[1712]: 606273.24 CuilApp   User admin(1001) successfully changed configuration 'Config/NetworkServices[1]/HTTPS[1]/VerifyServerCertificate[1]' to 'Off' from 10.3.1.212.
Sep  9 07:05:41.705 a8 appl[1712]: 606273.66 CuilApp   User admin(1001) successfully changed configuration 'Config/Provisioning[1]/Mode[1]' to 'Tms' from 10.3.1.212.
Sep  9 07:05:41.950 a8 appl[1712]: 606273.91 CuilApp   User admin(1001) successfully changed configuration 'Config/Provisioning[1]/ExternalManager[1]/Protocol[1]' to 'http' from 10.3.1.212.
Patrick Sparkman
It's TMS that is changing it, I assume 10.3.1.212 is your TMS IP?
By default, I believe TMS will use HTTP to communicate to it's managed systems, you can force it to use HTTPS by setting "Secure-Only Device Communication" in Administrative Tools > Configuration > Network Settings.
If you upgrade to TMS 15, the default is HTTPS, however fallback to HTTP if it doesn't connect.
Thank you very much.  I went in and made the change, and pushed the template back out.  I will verify tomorrow that it stuck, but I'm pretty confident in that.  I also changed the "URL Where Software Packages Can Be Downloaded" to HTTPS, so that quite possibly will fix the update issue as well.
Update*** Tried to update a system through system upgrade on TMS, and it showed 100% event successful on the System Upgrade Activity Status.  However, the system never updated.  I restarted the system as well, and it still did not upgrade.
I have CISCO 8865 VDO phone and other model of cisco ip phone as well and want to connect with my TMS its version is 15 , is it possible to connect these VDO phone to my TMS ??? and what is the procedure to connect with my TMS ??? further how to book conference in these VDO Phone ??? is it possible book conference ??? kindly help us
Fahad, refer to the thread you created, CISCO 8865 Vdo phone integrate with TMS, for answers to your question instead of asking it in a thread that is years old.
