TMS - Endpoint firmware update scheduling
GavP
I'm having a play around with the "System Upgrade" capability in TMS with a view to using it to perform some endpoint firmware updates. I scheduled a software update event for a time when I knew the target endpoint would be off, to see what would happen.
What happened was that the scheduled event in TMS triggered and then failed as it was unable to contact the endpoint. I noticed in the activity failure details it mentioned "Recurrence: Only Once", but I'm not able to see where I can set the recurrence frequency for the software update event.
What I would really like is for a scheduled software update event to retry at a later time if the target endpoint is offline when the event first triggers. Is this possible within TMS? If so, where would I look to configure this up?
Cheers,
Patrick Sparkman
it's only possible to schedule a single software upgrade at a time, TMS doesn't support scheduling software upgrades on a recurring schedule.
