endpoints running TC software can not be accessed by TMS
gfolens
Level 4
Level 4
I noticed the following strange behaviour after changing some parameters on some endpoints running TC5 (EX90) & TC6 (MX300) software.
All endpoints are registered to CUCM v8.6.
All endpoints correctly listed in TMS before the changes.
For 2 endpoints connected to different CUCM and different TMS I suddenly got 'no http response' as status in TMS navigator.
When I try 'Force Refresh' the status stays the same.
When I purge the endpoint from TMS and re-add them 'From List' -> 'Unified CM' I get an error and as 'Add Result' = 'Could not add the system in the folder'.
The endpoint can be reached from a webbrowser in HTTP without problems...
When I do a factory reset of the endpoint I can add it again to TMS.
The same changes have been done on other endpoints and they did not show the problem.
Any ideas what could be wrong?
mahkrish
Level 3
Level 3
Hi, what is the tms software version installed ? And what was the changes you had made before ?
BR, Mahesh Adithiyha
v14.1.1
A number of changes have been done via CLI such as Provisioing, phonebook, etc.
The same changes have been done on other endpoints without problems.
Hi, Can you help to share the xconfig output from one of the no http response system. I will compare with my Lab and revert with inputs.
Also Cisco Unified CM provisioned endpoints will get their phone books  from  the UCM itself. There is no way of deploying them in a CUCM/TMS  'mixed  mode' where they are registered to the UCM for provisioning and  to TMS  for phone books.
For  this feature roadmap details, please reach out to Cisco Sales/Account  Team of your region and they shall check and revert with inputs.
Hello Mahesh,
I'm not trying to implement the phonebook on both TMS & CUCM.
Hereafter the xconfig output.
*c xConfiguration Audio Volume: 33
*c xConfiguration Audio SoundsAndAlerts RingVolume: 31
*c xConfiguration Audio SoundsAndAlerts RingTone: Jazz
*c xConfiguration Audio SoundsAndAlerts KeyTones Mode: On
*c xConfiguration Audio Microphones Mute Enabled: True
*c xConfiguration Audio Input HDMI 1 Mode: On
*c xConfiguration Cameras PowerLine Frequency: 50Hz
*c xConfiguration Cameras Camera 1 Brightness Mode: Auto
*c xConfiguration Cameras Camera 1 Brightness Level: 1
*c xConfiguration Cameras Camera 1 Whitebalance Mode: Auto
*c xConfiguration Cameras Camera 1 Whitebalance Level: 1
*c xConfiguration Cameras Camera 1 Focus Mode: Auto
*c xConfiguration Cameras Camera 1 Backlight: Off
*c xConfiguration Cameras Camera 1 Mirror: Auto
*c xConfiguration Cameras Camera 1 Flip: Auto
*c xConfiguration Cameras Camera 1 DHCP: Off
*c xConfiguration Cameras Camera 1 Gamma Mode: Auto
*c xConfiguration Cameras Camera 1 Gamma Level: 0
*c xConfiguration Cameras Camera 1 IrSensor: On
*c xConfiguration Conference 1 AutoAnswer Mode: Off
*c xConfiguration Conference 1 AutoAnswer Mute: Off
*c xConfiguration Conference 1 AutoAnswer Delay: 0
*c xConfiguration Conference 1 MicUnmuteOnDisconnect Mode: On
*c xConfiguration Conference 1 DoNotDisturb Mode: Off
*c xConfiguration Conference 1 DoNotDisturb DefaultTimeout: 60
*c xConfiguration Conference 1 FarEndControl Mode: On
*c xConfiguration Conference 1 FarEndControl SignalCapability: On
*c xConfiguration Conference 1 Encryption Mode: BestEffort
*c xConfiguration Conference 1 DefaultCall Protocol: Sip
*c xConfiguration Conference 1 DefaultCall Rate: 1152
*c xConfiguration Conference 1 MaxTransmitCallRate: 6000
*c xConfiguration Conference 1 MaxReceiveCallRate: 6000
*c xConfiguration Conference 1 MaxTotalTransmitCallRate: 10000
*c xConfiguration Conference 1 MaxTotalReceiveCallRate: 10000
*c xConfiguration Conference 1 VideoBandwidth Mode: Dynamic
*c xConfiguration Conference 1 VideoBandwidth MainChannel Weight: 5
*c xConfiguration Conference 1 VideoBandwidth PresentationChannel Weight: 5
*c xConfiguration Conference 1 PacketLossResilience Mode: On
*c xConfiguration Conference 1 Presentation Policy: LocalRemote
*c xConfiguration Conference 1 Presentation RelayQuality: Sharpness
*c xConfiguration Conference 1 Presentation OnPlacedOnHold: NoAction
*c xConfiguration Conference 1 Multipoint Mode: Auto
*c xConfiguration Conference 1 IncomingMultisiteCall Mode: Deny
*c xConfiguration Experimental Conference 1 ReceiverBasedDownspeeding: On
*c xConfiguration Experimental Conference 1 PacketLossResilience ForwardErrorCorrection: OnWithUniqueSsrc
*c xConfiguration Experimental Conference 1 PacketLossResilience RateAdaption: On
*c xConfiguration Experimental Conference 1 Multistream Mode: Off
*c xConfiguration Experimental Conference 1 Multistream AudioInputCount: 3
*c xConfiguration Experimental Conference 1 Multistream InputCount: 3
*c xConfiguration Experimental Conference 1 Multistream OutputCount: 1
*c xConfiguration Experimental Conference 1 Multistream SimulcastQualities: 3
*c xConfiguration Experimental Conference 1 Multistream Stream 1 Source: 1
*c xConfiguration Experimental Conference 1 Multistream Stream 2 Source: 1
*c xConfiguration Experimental Conference 1 Multistream Stream 3 Source: 1
*c xConfiguration Experimental Conference 1 Multistream Stream 4 Source: 1
*c xConfiguration Experimental CapsetFilter: ""
*c xConfiguration Experimental CapsetReduction: Auto
*c xConfiguration Experimental NetworkServices UPnP Mode: On
*c xConfiguration Experimental NetworkServices UPnP Timeout: 600
*c xConfiguration Experimental NetworkServices Medianet Metadata: Off
*c xConfiguration Experimental SystemUnit MenuType: Full
*c xConfiguration Experimental SystemUnit SoftwareUpgrade RequireAuthentication: On
*c xConfiguration Experimental SystemUnit CrashReporting Mode: Off
*c xConfiguration Experimental SystemUnit CrashReporting URI: ""
*c xConfiguration Experimental Audio EcReferenceDelay: 0
*c xConfiguration Experimental CustomSoftbuttons HoldResume: Off
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 1 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 1 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 2 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 2 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 3 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 3 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 4 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 4 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 5 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 5 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 1 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 1 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 2 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 2 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 3 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 3 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 4 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 4 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 5 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 5 Value: ""
*c xConfiguration FacilityService Service 1 Type: Helpdesk
*c xConfiguration FacilityService Service 1 Name: "MIS Helpdesk"
*c xConfiguration FacilityService Service 1 Number: "3333"
*c xConfiguration FacilityService Service 1 CallType: Audio
*c xConfiguration FacilityService Service 2 Type: Emergency
*c xConfiguration FacilityService Service 2 Name: "Guards"
*c xConfiguration FacilityService Service 2 Number: "3008"
*c xConfiguration FacilityService Service 2 CallType: Video
*c xConfiguration FacilityService Service 3 Type: Helpdesk
*c xConfiguration FacilityService Service 3 Name: ""
*c xConfiguration FacilityService Service 3 Number: ""
*c xConfiguration FacilityService Service 3 CallType: Video
*c xConfiguration FacilityService Service 4 Type: Helpdesk
*c xConfiguration FacilityService Service 4 Name: ""
*c xConfiguration FacilityService Service 4 Number: ""
*c xConfiguration FacilityService Service 4 CallType: Video
*c xConfiguration FacilityService Service 5 Type: Helpdesk
*c xConfiguration FacilityService Service 5 Name: ""
*c xConfiguration FacilityService Service 5 Number: ""
*c xConfiguration FacilityService Service 5 CallType: Video
*c xConfiguration H323 NAT Mode: Off
*c xConfiguration H323 NAT Address: ""
*c xConfiguration H323 Profile 1 H323Alias ID: ""
*c xConfiguration H323 Profile 1 H323Alias E164: ""
*c xConfiguration H323 Profile 1 PortAllocation: Dynamic
*c xConfiguration H323 Profile 1 CallSetup Mode: Gatekeeper
*c xConfiguration H323 Profile 1 Gatekeeper Address: ""
*c xConfiguration H323 Profile 1 Gatekeeper Discovery: Manual
*c xConfiguration H323 Profile 1 Authentication LoginName: ""
*c xConfiguration H323 Profile 1 Authentication Password: ""
*c xConfiguration H323 Profile 1 Authentication Mode: Off
*c xConfiguration Network 1 Speed: Auto
*c xConfiguration Network 1 Assignment: DHCP
*c xConfiguration Network 1 IPStack: IPv4
*c xConfiguration Network 1 IPv6 Address: ""
*c xConfiguration Network 1 IPv6 Gateway: ""
*c xConfiguration Network 1 IPv6 Assignment: Autoconf
*c xConfiguration Network 1 IPv6 DHCPOptions: On
*c xConfiguration Network 1 QoS Mode: Diffserv
*c xConfiguration Network 1 QoS Diffserv Audio: 46
*c xConfiguration Network 1 QoS Diffserv Data: 32
*c xConfiguration Network 1 QoS Diffserv Signalling: 24
*c xConfiguration Network 1 QoS Diffserv Video: 34
*c xConfiguration Network 1 QoS Diffserv ICMPv6: 0
*c xConfiguration Network 1 QoS Diffserv NTP: 0
*c xConfiguration Network 1 DNS Server 1 Address: ""
*c xConfiguration Network 1 DNS Server 2 Address: ""
*c xConfiguration Network 1 DNS Server 3 Address: ""
*c xConfiguration Network 1 DNS Domain Name: ""
*c xConfiguration Network 1 IEEE8021X Mode: Off
*c xConfiguration Network 1 IEEE8021X TlsVerify: Off
*c xConfiguration Network 1 IEEE8021X UseClientCertificate: Off
*c xConfiguration Network 1 IEEE8021X AnonymousIdentity: ""
*c xConfiguration Network 1 IEEE8021X Identity: ""
*c xConfiguration Network 1 IEEE8021X Password: ""
*c xConfiguration Network 1 IEEE8021X Eap Md5: On
*c xConfiguration Network 1 IEEE8021X Eap Ttls: On
*c xConfiguration Network 1 IEEE8021X Eap Tls: On
*c xConfiguration Network 1 IEEE8021X Eap Peap: On
*c xConfiguration Network 1 MTU: 1500
*c xConfiguration Network 1 TrafficControl Mode: On
*c xConfiguration Network 1 RemoteAccess Allow: ""
*c xConfiguration Network 1 VLAN Voice Mode: Auto
*c xConfiguration Network 1 VLAN Voice VlanId: 1
*c xConfiguration Network 1 IPv4 Address: ""
*c xConfiguration Network 1 IPv4 SubnetMask: ""
*c xConfiguration Network 1 IPv4 Gateway: ""
*c xConfiguration NetworkServices XMLAPI Mode: Off
*c xConfiguration NetworkServices Telnet Mode: Off
*c xConfiguration NetworkServices SSH Mode: On
*c xConfiguration NetworkServices SSH AllowPublicKey: On
*c xConfiguration NetworkServices HTTP Mode: On
*c xConfiguration NetworkServices HTTPS Mode: On
*c xConfiguration NetworkServices HTTPS VerifyServerCertificate: Off
*c xConfiguration NetworkServices HTTPS VerifyClientCertificate: Off
*c xConfiguration NetworkServices HTTPS OCSP URL: ""
*c xConfiguration NetworkServices HTTPS OCSP Mode: Off
*c xConfiguration NetworkServices SNMP Mode: ReadOnly
*c xConfiguration NetworkServices SNMP CommunityName: "public"
*c xConfiguration NetworkServices SNMP SystemContact: "INS"
*c xConfiguration NetworkServices SNMP SystemLocation: "S3A-OFF-03"
*c xConfiguration NetworkServices SNMP Host 1 Address: "betmsl01"
*c xConfiguration NetworkServices SNMP Host 2 Address: ""
*c xConfiguration NetworkServices SNMP Host 3 Address: ""
*c xConfiguration NetworkServices H323 Mode: Off
*c xConfiguration NetworkServices SIP Mode: On
*c xConfiguration NetworkServices NTP Mode: Manual
*c xConfiguration NetworkServices NTP Address: "10.60.95.1"
*c xConfiguration NetworkServices MultiWay Address: ""
*c xConfiguration NetworkServices MultiWay Protocol: Auto
*c xConfiguration NetworkServices CTMS Mode: On
*c xConfiguration NetworkServices CTMS Encryption: Off
*c xConfiguration Phonebook Server 1 ID: "default"
*c xConfiguration Phonebook Server 1 Type: CUCM
*c xConfiguration Phonebook Server 1 URL: "
https://10.60.95.2:8443/cucm-uds/users
*c xConfiguration Provisioning Mode: CUCM
*c xConfiguration Provisioning LoginName: ""
*c xConfiguration Provisioning Password: ""
*c xConfiguration Provisioning HttpMethod: POST
*c xConfiguration Provisioning ExternalManager Address: "10.60.95.1"
*c xConfiguration Provisioning ExternalManager Protocol: HTTP
*c xConfiguration Provisioning ExternalManager Path: ""
*c xConfiguration Provisioning ExternalManager Domain: ""
*c xConfiguration Provisioning Connectivity: Auto
*c xConfiguration RTP Ports Range Start: 2326
*c xConfiguration RTP Ports Range Stop: 2486
*c xConfiguration Security Audit Server Address: ""
*c xConfiguration Security Audit Server Port: 514
*c xConfiguration Security Audit OnError Action: Ignore
*c xConfiguration Security Audit Logging Mode: Internal
*c xConfiguration Security Session ShowLastLogon: On
*c xConfiguration Security Session InactivityTimeout: 600
*c xConfiguration SerialPort Mode: On
*c xConfiguration SerialPort BaudRate: 38400
*c xConfiguration SerialPort LoginRequired: On
*c xConfiguration SIP Profile 1 URI: "
+3236553372@10.60.95.2
*c xConfiguration SIP Profile 1 DisplayName: "
+323655332@S3A-OFF-03
*c xConfiguration SIP Profile 1 DefaultTransport: TCP
*c xConfiguration SIP Profile 1 TlsVerify: Off
*c xConfiguration SIP Profile 1 Type: Cisco
*c xConfiguration SIP Profile 1 Outbound: Off
*c xConfiguration SIP Profile 1 Proxy 1 Discovery: Manual
*c xConfiguration SIP Profile 1 Proxy 1 Address: "10.60.95.2"
*c xConfiguration SIP Profile 1 Proxy 2 Discovery: Manual
*c xConfiguration SIP Profile 1 Proxy 2 Address: ""
*c xConfiguration SIP Profile 1 Proxy 3 Discovery: Manual
*c xConfiguration SIP Profile 1 Proxy 3 Address: ""
*c xConfiguration SIP Profile 1 Proxy 4 Discovery: Manual
*c xConfiguration SIP Profile 1 Proxy 4 Address: ""
*c xConfiguration SIP Profile 1 Authentication 1 LoginName: ""
*c xConfiguration SIP Profile 1 Authentication 1 Password: ""
*c xConfiguration SIP ListenPort: On
*c xConfiguration Standby Control: On
*c xConfiguration Standby Delay: 10
*c xConfiguration Standby WakeupAction: RestoreCameraPosition
*c xConfiguration Standby BootAction: DefaultCameraPosition
*c xConfiguration Standby StandbyAction: PrivacyPosition
*c xConfiguration SystemUnit Name: "S3A-OFF-03"
*c xConfiguration SystemUnit MenuLanguage: English
*c xConfiguration SystemUnit ContactInfo Type: Auto
*c xConfiguration SystemUnit CallLogging Mode: On
*c xConfiguration SystemUnit IrSensor: Auto
*c xConfiguration Time Zone: GMT+01:00 (Brussels, Copenhagen, Madrid, Paris)
*c xConfiguration Time TimeFormat: 24H
*c xConfiguration Time DateFormat: DD_MM_YY
*c xConfiguration UserInterface TouchPanel DefaultPanel: MeetingList
*c xConfiguration Video Selfview: Off
*c xConfiguration Video SelfviewDefault Mode: Off
*c xConfiguration Video SelfviewDefault FullscreenMode: Current
*c xConfiguration Video SelfviewDefault PIPPosition: Current
*c xConfiguration Video SelfviewDefault OnMonitorRole: Current
*c xConfiguration Video PIP ActiveSpeaker DefaultValue Position: Current
*c xConfiguration Video PIP Presentation DefaultValue Position: Current
*c xConfiguration Video Wallpaper: Waves
*c xConfiguration Video MainVideoSource: 1
*c xConfiguration Video DefaultPresentationSource: 2
*c xConfiguration Video Layout Scaling: On
*c xConfiguration Video Layout ScaleToFrame: MaintainAspectRatio
*c xConfiguration Video Layout ScaleToFrameThreshold: 5
*c xConfiguration Video Layout LocalLayoutFamily: Auto
*c xConfiguration Video Layout RemoteLayoutFamily: Auto
*c xConfiguration Video Monitors: Dual
*c xConfiguration Video Input Source 1 Name: "Camera"
*c xConfiguration Video Input Source 1 Type: camera
*c xConfiguration Video Input Source 1 Connector: HDMI
*c xConfiguration Video Input Source 1 PresentationSelection: Manual
*c xConfiguration Video Input Source 1 CameraControl Mode: On
*c xConfiguration Video Input Source 1 CameraControl CameraId: 1
*c xConfiguration Video Input Source 1 Quality: Motion
*c xConfiguration Video Input Source 1 OptimalDefinition Profile: Medium
*c xConfiguration Video Input Source 1 OptimalDefinition Threshold60fps: 1280_720
*c xConfiguration Video Input Source 2 Name: "PC"
*c xConfiguration Video Input Source 2 Type: PC
*c xConfiguration Video Input Source 2 Connector: DVI
*c xConfiguration Video Input Source 2 PresentationSelection: Manual
*c xConfiguration Video Input Source 2 CameraControl Mode: Off
*c xConfiguration Video Input Source 2 CameraControl CameraId: 1
*c xConfiguration Video Input Source 2 Quality: Sharpness
*c xConfiguration Video Input Source 2 OptimalDefinition Profile: Medium
*c xConfiguration Video Input Source 2 OptimalDefinition Threshold60fps: 1280_720
*c xConfiguration Video Input HDMI 1 RGBQuantizationRange: Auto
*c xConfiguration Video Input DVI 2 RGBQuantizationRange: Full
*c xConfiguration Video Input DVI 2 Type: AutoDetect
*c xConfiguration Video Output HDMI 1 RGBQuantizationRange: Full
*c xConfiguration Video Output HDMI 1 Resolution: Auto
*c xConfiguration Video Output HDMI 1 OverscanLevel: None
*c xConfiguration Video Output HDMI 1 CEC Mode: Off
*c xConfiguration Video Output HDMI 1 MonitorRole: First
*c xConfiguration Video Output HDMI 2 RGBQuantizationRange: Full
*c xConfiguration Video Output HDMI 2 Resolution: Auto
*c xConfiguration Video Output HDMI 2 OverscanLevel: None
*c xConfiguration Video Output HDMI 2 CEC Mode: Off
*c xConfiguration Video Output HDMI 2 MonitorRole: Second
*c xConfiguration Video AllowWebSnapshots: Off
*c xConfiguration Video SelfviewPosition: LowerRight
*c xConfiguration Video OSD MenuStartupMode: Home
*c xConfiguration Video OSD VirtualKeyboard: UserSelectable
*c xConfiguration Video OSD EncryptionIndicator: Auto
*c xConfiguration Video OSD MissedCallsNotification: On
*c xConfiguration Video OSD Mode: On
*c xConfiguration Video OSD AutoSelectPresentationSource: On
*c xConfiguration Video OSD TodaysBookings: Off
*c xConfiguration Video OSD MyContactsExpanded: Off
*c xConfiguration Video OSD Output: 1
*c xConfiguration Video OSD InputMethod InputLanguage: Latin
*c xConfiguration Video OSD InputMethod Cyrillic: Off
*c xConfiguration Video OSD LoginRequired: Off *c xConfiguration Audio Volume: 33
*c xConfiguration Phonebook Server 1 URL: "https://10.60.95.2:8443/cucm-uds/users"
*c xConfiguration SIP Profile 1 URI: "+3236553372@10.60.95.2"
*c xConfiguration SIP Profile 1 DisplayName: "+323655332@S3A-OFF-03"
