EQ Codec with 2x PTZ 4k Cameras for Speaker and Audience
mjtk
Installing 2x PTZ 4K cameras connected to a Codec EQ which also has 3x Cisco ceiling mics running off it.
Ideally I need one camera pointing at the presenter in presenter track mode and one camera pointing at the audience with speaker track capabilities. Is this possible in MTR mode without the quad cam? It seems I'm running into some limitations when configuring.
mjtk
Latest limitation is that I've got both cameras set up and connected. They are coming through on the MS teams call nicely. However I only seem to be able to manually control 1 camera from the navigator itself. Do you need to add the second camera controls? The nav doesn't seem to pick it up automatically.
sveistef
depending on what inputs you have used, it may be as simple as you need to enable cameracontrol on that input. For input 2 on an EQ, it's default off.
[xConfiguration Video Input Connector[2] CameraControl Mode](https://roomos.cisco.com/xapi/Configuration.Video.Input.Connector[2].CameraControl.Mode/)
