EQ using HDMI for output on 3 screens with EQ with presentertrack mode
Latnok007
Hello All,
looking for any solution which can help to route the audio on 3 screens on the same time instead of quad cam or 1 tv only?
best regards
If you need to customise the audio to that level on a Room EQ, you will need to have the Integrator Option Key installed.   You can then use the Audio Console that is part of the Web Interface on the device to customise where the audio goes.   See "The Audio Console panel" section of the Admin Guide.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne
Dear @Wayne DeNardi  thank you so much.
