06-23-2019 02:19 AM
I am trying to find the command to disable the local clock and date ICONs on the monitor ... anyone have a solution.
It pops up at random times also???
I am using a touch panel to control the system and not a hand held remote and have the OSD mode OFF ??
Also the UserInterface User Pref is Off and TouchPanel DefaultPanel - "DialPad"
Thank you.
Solved! Go to Solution.
06-27-2019 08:15 PM
Seems to be a duplicate of this thread: https://community.cisco.com/t5/telepresence-and-video/ex90-clock-and-date-display-issue-tc7-3-7/m-p/3878305
As mentioned in the other thread, you should change the Experimental setting "SystemUnit MenuType" from "Interactive" to "Indicators".
Please remember to mark helpful responses and to set your question as answered if appropriate.
06-27-2019 08:15 PM
