EX90 touch panel issue
zaziz
Only the bottom row of alpahbet menu is not working. Rest are fine.
Simple reboot has not fixed the issue.
Lyn Dickerson
5.1.4 corrected my touch panel woes.
Sent from Cisco Technical Support Android App
Teck Chye Tang
This is a known defect in some panel. If you continue to face this issue, you should RMA the touch panel.
