EX90 with dual monitors
tbieler11
                   Is it possible to set the EX90 to use dual output displays to a larger external monitor?
5 Replies 5
mubakhta
Level 4
Level 4
Hi Tracy,
Yes it is possible to do that. You can attach another monitor and configure the Ex90 to have two monitors. You can use the HDMI output port on the back of Ex90. However, you will not be able to get audio from the second screen and only Presentation and Main Video would be possible.
Hope this answers your question.
Mubashshir Akhtar
Thanks Mubashshir Akhtar
Can you tell us how to get the main video on both the EX90 and also the external monitor?
Tracy
xConfiguration Video Monitors or
Advanced Configuration> Video from Web GUI
Single: The same layout is shown on all monitors.
Dual: The layout is distributed on two monitors.
DualPresentationOnly: All participants in the call will be shown on the first monitor, while the
presentation (if any) will be shown on the second monitor
br Oleksandr
Hi Tracy/all
You will ONLY be able to use the second screen for presentations (both local and external). The camera is locked to the primary monitor, and there is no way you can manipulate picture from the EX90 screen to the secondary screen.
I have had a chat directly with people in EX90 R&D team to confirm this.
Unfortunately there is an error in the EX90 admin guide, telling you that this is a supported feature which it is not.
Sorry for this confusion
//Marius
Hi Tracy
Yes. But you need buy Dual Display Option for EX90
br Oleksandr
