Example CSV file for migrating on prem VCS to cloud onboarding
Robert McNeill
Does anyone have an example of the format of the CSV file for migrating op prem endpoints to control hub using the device connector tool?
I did this per the instructions:
"To create the file from TMS, export a System Overview report and only select the Network Settings > Hostname system parameter. Manually add columns for Username and Password.
For the CSV file, you need to create columns for Address, Username, and Password."
When I try to upload the CSV file, I am getting an invalid format error.
Unfortunately, Cisco did not put an example in their instructions...
lzhu
This is what I used when I migrated our on-prem video endpoints to Control Hub.
