10-23-2017 07:50 PM - edited 03-18-2019 01:33 PM
Hi All,
We have expressway edge and core and their current version is 8.8. Security team told us that they receive notification about the SSL certificate is supporting TLS 1.0 and SHA1 which has a bad rating for vulnerability. May we know on how can we address it?
I tried searching the latest version of expressway which is 8.10.2 and found below information.
From version 8.8 release note, i have seen this information below.
Appreciate if you can help us on how to resolve or address this issue of vulnerability regarding ssl certificate. Can we disable TLS 1.0 and SHA1 or do we need to upgrade the version of expressway to 8.10.2?
Thank you.
10-23-2017 10:05 PM
10-23-2017 10:22 PM
Hi Patrick,
Thank you so much for the recommendation. Am I correct to say that we can directly upgrade from X8.8 to X8.10.2?
10-23-2017 10:31 PM
Yes, you can upgrade directly, and no release key isn't required.
10-23-2017 10:39 PM
Great. Thank you so much. We will try to upgrade the expressway and update this discussion once done.
