Expressway-C to IM&P: "AXL query HTTP error "'HTTPError: 404'"
dsobrinho
Level 9
Level 9
Hi team,
We are facing this problem with Federation (Expressway C|E with IM&P).
The services like MRA and B2B is working fine.
In debug we have this information below:
2017-08-17T14:24:50.893-03:00 ACMEIMPSERVER 1 management: Level="WARN" Event="Unified Communications server configuration" Detail="Failed to communicate with server" Host="acmeimpserver.acme.com.br" Reason="HTTP Error" Error="'HTTPError: 404'" UTCTime="2017-08-17 17:24:50,893"
2017-08-17T14:24:50.893-03:00 ACMEIMPSERVER management: UTCTime="2017-08-17 17:24:50,892" Module="developer.management.xcpmanager" Level="ERROR" CodeLocation="axlquery(596)" Detail="cups address not found in cluster query list"
2017-08-17T14:24:50.893-03:00 ACMEIMPSERVER management: UTCTime="2017-08-17 17:24:50,893" Module="developer.management.xmppdiscovery" Level="ERROR" CodeLocation="ucqueryrun(128)" Detail="AXL error" Host="acmeimpserver.acme.com.br" Reason="HTTP Error" Error="'HTTPError: 404'"
Does anybody know something like that?
Best regards
Daniel Sobrinho
Daniel Sobrinho
Frank den Haan
Level 4
Level 4
We are having the same issue. Started right after upgrading CUCM and IM&P to 11.5.1 SU3. Everything all seems to be working fine though (MRA and B2B).
Did you happen to find a solution?
Frank
This got resolved. On CUCM under System > Server, the IM&P FQDN was in upper case and on Expressway-C under Configuration > Unified Communications > IM and Presence Service nodes
it was in lower case. It was never an issue when on 10.5.2, but since 11.5.1 SU3 it seemed to be a problem.
Two solutions work:
Delete the IM&P entry on Expressway-C and re-add it in upper case like it is on CUCM (another engineer I know resolved it this way).
Or
Try and add the IM&P name on Expressway-C in upper case, it generated an error message (time out, socket error), just ignore it, go back to the IM&P entry already on Expressway-C in lower case, check the box and click “Refresh”. It resolved it (this worked for me).
This is CSCvc90758.
