Expressway SW
George Clark
question i have a Expressway-c & E running 12.5.5 i want to upgrade them does anyone know the latest version before u get into smart licensing i have looked and cant find it ???
I currently don't want to do smart licensing
Jaime Valencia
Have you reviewed the RNs from newer releases for that information?
java
if this helps, please rate
Jaime Valencia
java
In Expressway as of current versions, we’re on 12.6.4, you would opt-in to Smart Licensing. Aka it’s a continuous choice you have to do in the UI, your not going to get forced into it just because you upgrade to a version that has the functionality for Smart License.
Response Signature
