Expressway x8.9 TLS v1.2
allahverdiyev
Hello guys,
Can you help me to make sure Expressway x8.9 supports TLSv1.2?
Default configuration is:
xConfiguration SIP TLS CipherSuite: ALL:!EXP:!LOW:!MD5:@STRENGTH:+ADH
xConfiguration SIP Advanced SipTlsVersions: "TLSv1:TLSv1.1:TLSv1.2
regards
5 Replies 5
PJMack
Level 7
Level 7
From page 483 of the admin guide:
To improve security, the Expressway now only supports specific versions of TLS. The Expressway offers and accepts TLS versions 1.0, 1.1, and 1.2, when establishing secure connections.
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/admin_guide/Cisco-Expressway-Administrator-Guide-X8-9.pdf
I have read documentation. This does not give much information, says just Expressway offers and accepts. I am asking of how to check if it is actually, currently supporting TLS v1.2 if called destination is only TLS v1.2 supported.
Mohammed Khan
Below command should provide what system currently supports
*c xConfiguration SIP Advanced SipTlsVersions: "TLSv1.2"
To modify the configuration use below command
xConfiguration SIP Advanced SipTlsVersions: "TLSv1.1:TLSv1.2"
OK
*c xConfiguration SIP Advanced SipTlsVersions: "TLSv1.1:TLSv1.2"
OK
HTH,
Mohammed Noor
Mohammed Khan,
I don't see difference between what you offer and default configuration. What is the difference?
According to default config, as I understoon it supports TLS v1.2 correct?
Default configuration has 1.2 enabled. If required you may have to add 1.1 in the configuration.
Mohammed Noor
