External URI dialling from CUCM
Tolulope Osho
Dear All,
I currently have a lab setup for communication between Cisco CUCM and the Cisco VCS. Below is what I have been able to achieve to far
Call from CUCM to endpoints registered to the VCS
Calls from endpoints registered to the VCS to endpoints registered to the CUCM
What I want to achieve is external URI dialling from the CUCM to external domains via the VCS Expressway.
If for example I dial charles@externaldomain.com, it get resolved to charles@ip-address of VCS (configured on the trunk between the CUCM and the VCS). This I know is a default behavior.
 I need to know how I can modify the CUCM such that it deliver the exact address I am trying to dial i.e. charles@externaldomain.com to the VCS without any modification done
Osho
heathrw
Level 4
Level 4
What version of CUCM and VCS are you currently running?
What is your CUCM and VCS setup/detail as in:
  • CUCM: VCS SIP Trunk (SIP trunk Profile and SIP Trunk Security Profile)
  • CUCM: Route Patterns
  • CUCM: SIP Route Patterns
  • CUCM: SIP Normalization Rule applied to the trunk
  • VCS Control: Can you attach a search history output
heathrw
Level 4
Level 4
Thanks heathrw
I checked my search rules and realised that the calls were sent with the :5060 appended.
I created a transform to strip this off and calls to external domains are now successful.
Thanks for pointing this out.
Osho
