Hi to all
I will try to give you an idea what we have setup and what is the senario
Central infrastracture : CTM,CTMS,CUCM,CUVC,2911 with 10 MB line for the external video calls
Endpoints: 5 CTS
We want to establish a video conference with external video conferencing systems via the internet
The senario that we have done is: 10 MB line in the 2911 Router .configure NAT that is point to the CUVC.(CTS dial the static number in the CTMS which is configured with interoperability number and then the CTMS open a cascade with the CUVC succesfully.)
The call going succesfull to CUVC from the external video conferencing systems but it looks that the DTMF is not responding.we touch the Keypad in the tandberg but is not responding..
Note that we have test the setup internally (Two Standalone Tandbergs dial with SIP or H323 to CUVC and one CTS dial the CTMS)and everything was ok..)
The problem is only from the outside network
Is the Senario with the NAT correct?.Should we change this senario?
Pls advice
cc
Please rate all useful posts
Chrysostomos
""The Most Successful People Are Those Who Are Good At Plan B""
