EXTERNAL VIDEO CONFERENCE DROP AFTER ANY SECONDS
Hi;
I have a TMS version 15.3.0 and TMSXE 5.3 version,
I have an enviroment, with:
CUCM 10.5.2.10000-5
PRESENCE 10.5.2.21900-4
TMSPE: 1.7
CONDUCTOR: 4.2
EXPRESSAY NODES: 8.6 ( clusters EXP-E and cluster EXP-C )
TELEPRESENCE SERVER:4.2(4.23)
Hi;
When I create a new video conference, using SMART SCHEDULER or CMR, an user external can not remain in a conference, this connection is dropped after any seconds.  In my vts logs exist the message below, where inform that closing call due to failed reINVITE SIP.
 274 2016/09/12 16:47:47.768 SIP                      Info      Incoming call from 10.254.0.30:42033
      275 2016/09/12 16:47:47.771 APP                      Info      call 21: new incoming SIP call from "9405@cbmm.com.br"
      276 2016/09/12 16:47:47.953 APP                      Info      call 21: "FABIO 2S" now joined conference "Reuniao Agendada 9/12/2016 4:24 PM"
      277 2016/09/12 16:48:09.340 APP                      Info      call 21: stopped contributing video, now contributing audio only
      278 2016/09/12 16:48:10.706 NTP                      Info      time is Mon Sep 12 16:48:10 2016
      279 2016/09/12 16:48:16.058 SIP                      Info      Incoming call from 10.254.0.30:42033
      280 2016/09/12 16:48:16.061 APP                      Info      call 22: new incoming SIP call from "1232@vspcucm01.2s.com.br"
      281 2016/09/12 16:48:16.098 APP                      Info      call 22: "Leonardo Silva" now joined conference "Reuniao Agendada 9/12/2016 4:24 PM"
      282 2016/09/12 16:48:23.743 SIP                      Error     call 22: Closing call due to failed reINVITE
      283 2016/09/12 16:48:23.743 CMGR                     Info      call 22: disconnecting, "1232@vspcucm01.2s.com.br" - service unavailable
      284 2016/09/12 16:48:23.745 APP                      Info      call 22: tearing down call from "Leonardo Silva" - destroy at far end request; unavailable
      285 2016/09/12 16:48:23.835 SIP                      Warning   call 22: Unable to successfully terminate dialog with BYE
      286 2016/09/12 16:48:31.937 CMGR                     Info      call 21: disconnecting, "9405@10.254.0.8"
      287 2016/09/12 16:48:31.937 APP                      Info      call 21: tearing down call from "FABIO 2S" - destroy at far end request; remoteTeardown
I check any informations in othe case closed in this forum: https://supportforums.cisco.com/discussion/12294701/telepresence-server-active-control-drops-conference-after-30-seconds
But I did the recommendations , but with IX protocol disable in SIP PROFILE CONDUCTOR and MEETING ALIAS, the same error happens. My Max incoming message size is setting to 11000.
Internal conference happens normally.
Any idea?
Regards;
Fabio Santos
I've seen some similar behavior in the past - on the SIP trunk pointing to Expressway, try unticking the "SRTP Allowed" checkbox and see if it works.
Hi Nick;
I untick SRTP ALLOWED in my sip trunk with EXP-CORE and my dial out sip, using Smart Scheduler, TMS booking worked fine now.
Thanks a lot by it!
Regards;
Fabio Santos
