Extract Eventlog From VCS
Justin Ferello
Level 5
Level 5
Hey all,
What is the procedure to extract the entire eventlog from a VCS?  I would imagine it is stored in a file and that we could get it via WinSCP or via the CLI using 'root'?
Justin
Thank you,
Justin Ferello
Technical Support Specialist, ScanSource KBZ
awinter2
Level 7
Level 7
The eventlog is stored in /mnt/harddisk/log/messages.
Once the messages files reaches 10 MB or so, it is rotated and renamed messages.1 and a new messages file is spawned.
As far as I recall, we keep a total of 200 messages files in the rotation, and you can download these using your SCP client of choice (remember to log in as root rather than admin).
Hope this helps,
Andreas
awinter2
Level 7
Level 7
Hope this helps,
Andreas
Andreas,
Thank you so much for the information and how quickly you responded.
Justin
Thank you,
Justin Ferello
