07-06-2012 07:33 PM - edited 03-17-2019 11:25 PM
7/6/2012 9:06:46 PM | Event Created |
7/6/2012 9:06:50 PM | Event executed by TMS1 |
7/6/2012 9:06:50 PM | TMS agent data replication will be set up for the following system(s): vcscontrol1 |
7/6/2012 9:06:51 PM | Reading local TMS agent status |
7/6/2012 9:06:51 PM | Reading TMS agent status on 'vcscontrol1' |
7/6/2012 9:06:52 PM | Clearing replication setup on 'vcscontrol1' |
7/6/2012 9:11:52 PM | Failed to clear replication setup on 'vcscontrol1' |
7/6/2012 9:11:52 PM | Failed to enable TMS agent data replication for 'vcscontrol1' |
7/6/2012 9:11:52 PM | The event failed to complete. Details: TMS agent data replication setup failed for the following system(s): vcscontrol1 |
Need help enabling data replication please.
Using Version 13.2 and V7.1
Any assistance or suggestion would be appreciated. Trying to enable TMS...please help.
07-07-2012 02:43 AM
Hello Roberto
Was this working before or did you just upgrade?
When you run diagnostic on TMS for local and vcs agent? What errors do you see?
Rafal
07-07-2012 07:59 AM
It was working. They did the upgrade in May and since then we haven't added any users. Go figure I had to add a user.
The diagnostic had me turn off the vcscontrol tms agent and enable it. I was able to disable it but not enable it.
I checked the disable logs and it had this error "Failed to clear replication setup" just like the enable logs. The TMS server has been restarted but haven't touched the VCS system since I am not the admin for the system.
04-09-2013 06:28 AM
hi Everyone,
even Im facing the same issue as Roberto mentioned above, kindly some1 suggest to get it resolved.
thanks in advance
Nikhil
04-09-2013 08:31 AM
Hi Roberto, There could various reasons for TMSagent replication failure.
I would recommend you opening a tac case to have this resolved and also upgrade to TMSPE.
I’ve consolidated the required document links below for your quick reference prior upgrading to TMSPE.
TMS 13.2
TMSPE 1.0
BR/Mahesh Adithiyha
