05-17-2012 01:00 PM - edited 03-17-2019 11:11 PM
I'm running VCS 7.0.3 and internittantly the users FindMe settings to forward to his Movi client will reset. The user or our IT staff have to go back into the FindMe configuration and reset it to forward to the Movi device. What could be causing this?
Solved! Go to Solution.
05-18-2012 04:41 AM
Hi Martin
Is there any pattern to when the findme setting dissappear?
I would toss a recommendation to migrate to the new provisionin model, the provisioning exxtension. Findme management has moved from the vcs to tms now and the new model is considered much more stable and scalable. The old model may be removed in one of our future major releases of TMS so it might be good to start looking at this. There will not be any further fixes to the old provisioning model if this identifies as a bug.
If you still want to troubleshoot it i would consider opening a tac case on this.
05-18-2012 04:41 AM
Hi Martin
05-18-2012 05:52 AM
There really isn't any pattern I can discern. I'll have to read up on the Provisioning Extension but I do currently use TMS to provision our Movi users.
