Firewall Ports - TX9000
Hi experts,
I need to set up a TX9000 which is behind a firewall. Is there any document that shows the ports that need to be released on the firewall for the Telepresence work perfectly? The version of CUCM is 9.1.2
I searched the community but found nothing, unfortunately the tool to search is not the best: /
Best Regards
Martin Koch
Did you check out this document?
http://www.cisco.com/c/en/us/td/docs/telepresence/security_solutions/1_8/CTSS/ctss_app_a.html
Thank you for reply Martin.
Do you know if this document apply for the new version of CTS (1.9) and TX (6.1)? Or at least for version CTS 1.9?
When I looked I did not find a newer document,
some newer documents linked to
http://www.cisco.com/en/US/docs/telepresence/security_solutions/ctss_app_a.html
but thats a dead link :-(
If you do not get a better answer here, think of reaching out to your Cisco Partner / Contact / TAC
