Floor stand for MX200. Compatibility with MX200 G2
emajcic
Hi Community,
A user is requesting a Floor stand for his MX200. I am wondering if a MX200 G2 or MX300 G2 is compatible?
I have looked the the install guides for both and it appears that there is no difference between the floor stand for a MX200 G2 or MX200.
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/mx-series/installation_guide/78-20004-02_mx200_floorstand_installation_sheet.pdf
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/mx-series/installation_guide/mx200-g2-floorstand-installation-sheet.pdf
Just like some in Cisco to confirm
Thanks in Advance
From the istallation guides, it looks similar. But comparing both  data sheet, there is a slight difference  in the Physical  dimensions mentioned with the floor stand.
Part number for MX200G2 floor stand is  CTS-MX200-FSK=. if G1 floor stand has the same part number. yes you can use.
Response Signature
