09-10-2003 05:43 AM - edited 03-17-2019 08:05 PM
ATA 186 version 2.16
Cisco 3662 12.2(15)T7
Open Source H.323 Gatekeeper
NAT translation with ALG
I am running an ATA186 connected into the inside interface of a 3662 running NAT. The outside interface has an open source H.323 Gatekeeper connected on the LAN.
Testing
Using Netmeeting I can connect through the NAT router and get a RAS RCF message back. Working OK.
Using the ATA 186 I get a failure.
Sends GRQ and gets GCF back.
Then sends a RRQ.
This is where it fails as the RRQ message has the non translated ("un-natted") source address of the ATA. The GK then sends a RRJ stating "invalid Call Signal Address".
It seems as though the layer 3 header IP src/dst is being translated but the higher layer information is unchanged. This is supposed to be taken care of by IOS Application Level Gateway (ALG) feature.
Anybody got any ideas??
09-12-2003 12:46 AM
Andy,
This sounds like it could be a bug. I would suggest capturing the following information, and then opening a case with Cisco TAC.
debug h225 asn1
debug cch323 ras
debug cch323 h225
debug ip nat h323
Ademola
09-26-2004 05:13 PM
this is bug H.323. It don't work with NAT. Just sip.
