H323 inbound call drops after 5 mins every time
Chenzhe Zhang
Hi Folks,
Can you shed some light on this please?
H.323 inbound call (dial by IP) -> External F5 -> Fortinet Firewall -> Internal F5 -> Internal Firewall -> VCS-E -> VCS-C -> MCU autoattendent
The call drops after 5 mins into the call, every single time. We tried H.323 call to an internal endpoint, it drops as well. Sounds like there is a timeout value set some where on he firewall or F5?
Any suggestions is appreciated!
regards
Chenzhe
I hope this helps:
http://www.cisco.com/c/en/us/td/docs/telepresence/infrastructure/articles/mcu_ip_gw_vcr_isdn_telepresence_server_calls_disconnect_fixed_time_kb_23.html
  1. Duration limits applied to network connections by firewalls. For example, a Cisco PIX firewall may have a timeout command of the form:
    timeout conn 1:00:00 udp 0:02:00 h225 1:00:00 h323 2:00:00<
    (i.e. a list of recognized protocol names each followed by a timeout in hours, minutes and seconds). This example imposes a 2-hour limit on H.323 connections; however, it also imposes limits on other protocols which would also affect a video call (UDP and H225). Many different network protocols are involved in an IP video call. A timeout applied to any of them could result in the call being torn down.
14 Replies 14
monster.speaks
There are H.323 inspection that has to be checked on the firewall, try disabling them and calls should work fine.
Thanks for the quick reply, and I will look into that.
Just wondering if the H323 inspection was the root cause, why only after 5 mins into the call? Should it not stop the call at the very beginning?
regarads
Chenzhe
Disable ALG for H323 application on the firewall. ALG could be the cause.
Acevirgil
I will try disabling them on all firewalls. Please see attached the screen shot, so will I just un-tick H323 related inspections, correct?
Thank you!
Yes. Un-ticking H323 inspections in your firewall will allow any H323 related packets to pass and allowing H323 traffic without inspection of the packets. Enabling ALG for H323 in some cases will modify the payload of the H.323 messages.
Acevirgil
Thanks for the quick reply. I am just trying to get my head around this, since we are seeing consistent call drops after 5 mins, do you think the inspection somehow breaks up the call every time after 5 mins? Or maybe the call shouldn't be able to establish at the beginning?
I hope this helps:
Thank you for the help, I will organize the change and see how we get on.
The issue is resolved. It was a timeout setting on the internet facing firewall - Fortigate FW. The troubleshooting involved doing packet captures on both interfaces of each F/W device one by one, and looking for the device that would have a difference in the number of keep alive messages received.
Wai wai
Hi Chenzhe,
Apologize to hijack your thread but I encountered the exactly some issue with you, the video call consistently keep dropped at every 5 minutes with H.323 protocol (dial-in or dial-out),
I have a firewall with ALG enable for both H.323 and SIP service protocol, find it strange that only H.323 call have this issue but not for SIP call, SIP protocol video call run perfectly fine.
Did disabling the firewall ALG for H.323 solve your issue?
Thanks in advance
Hi Wai wai,
Yes, the issue is resoved, please see my reply in the very bottom.
And no, disabling the ALG was not required, my understanding is that it should only be disabled if you couldn't get a call going at all. If there is an consistant pattern that the call drops at certain time, it has to be a timer somewhere.
Hi Chenzhe,
Would you mind share to me that what kind of timeout setting that you have change/tweak at your Internet firewall to make the H.323 call works? was it somehing like service (TCP/UDP) timeout setting?
Sure. What we did was that we went to the firewall rules for incoming H323 and H245, both signallin and media, and up'd the timeout value to 2 hours.
can you mark this post as answered..
