Having multiple sip domains for call control on VCS
                My customer is planning to migrate from abc.org to xyz.abc.org sip domain. We want to have both the sip domains, to make sure the migration is smooth. Am looking for some best practices or any documentation when using 2 sip domains for VCS(no MRA) & CUCM(no directory URI dialing,presence,unity,AD). Am trying to figure out what is the best way to migrate movi users(reg to VCS) and around 600 endpoints (reg to CUCM) from one sip domain to another. Please let me know if you have any suggestions.
mbowden7
I am currently dealing with this problem but a little further along. I have chosen to use the same domain it will be easier for in long run. The VCS has loop detection and you can push the priority to push calls to CUCM with that domain.
Or you can built a SIP truck and set priorities for both.
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/vcs/config_guide/X8-5/Cisco-VCS-SIP-Trunk-to-Unified-CM-Deployment-Guide-CUCM-8-9-10-and-X8-5.pdf
