HD resolution at 512kbps on MSE8510
Hi all,
Our customer  wants to establish a connection at 512kbps with HD(1280x720 30fps) quality between MSE8510(HD mode) and endpoint.
In our labo(MCU4510 and SX20), at least 768kbps was required for HD quality
Can MSE8510 send and receive video with HD quality at 512kbps?
Or is there any threshold of bandwidh for HD quality?
Best Regards,
Kotaro Hashimoto
Tomonori Taniguchi
MCU and Endpoint able to negotiate w720p on main video channel even call with 512kbps (depend on configuration on both MCU and Endpoint).
[Call between Endpoint and MCU8510 at 512kbps by using H323 as transport call protocol]
*s Call 1 (status=Synced, type=Vtlph, protocol=H323, direction=Outgoing, logTag=5):
     CallRate: 512
     RemoteNumber: "11085100"
     Mute: Off
     Microphone: On
     Duration: 6
     MuteOutgoing: Off
     CallOnHold: False
     RemoteSiteOnHold: False
     MultiwayProgress: Off
     Channels 1 (type=Incoming):
       Rate: 512
       Restrict: Off
       IPLR: Off
       Encryption (status=On):
         Type: AES-128
         CheckCode: "B1FFED47D97CE7CA"
       Audio (status=Active):
         Protocol: AAC-LD
         Rate: 64
       Video 1 (status=Active):
         Protocol: H264
         Resolution: w720p
         Rate: 448
       Video 2 (status=Inactive): /
      Data (status=Inactive): /
     Channels 2 (type=Outgoing):
       Rate: 512
       Restrict: Off
       IPLR: Off
         Type: AES-128
         Protocol: AAC-LD
         Rate: 64
         Protocol: H264
         Resolution: w720p
         Rate: 448
*s/end
However please note that negotiation is based on what is max resolution can be “decode” on local site, therefore with 512kbps, encoder won’t able to generate 30 frame in every seconds or will take a bit longer time before image became full stable view (due to available bandwidth for sending update image).
6 Replies 6
Tomonori Taniguchi
     CallRate: 512
     Mute: Off
     Microphone: On
     Duration: 6
     MuteOutgoing: Off
     CallOnHold: False
       Rate: 512
       Restrict: Off
       IPLR: Off
         Type: AES-128
         Protocol: AAC-LD
         Rate: 64
         Protocol: H264
         Resolution: w720p
         Rate: 448
       Rate: 512
       Restrict: Off
       IPLR: Off
         Type: AES-128
         Protocol: AAC-LD
         Rate: 64
         Protocol: H264
         Resolution: w720p
         Rate: 448
*s/end
Tomonori Taniguchi
BTW, depend on transmit image (how much motion in captured image), customer may have better experience with lower video resolution instead of forcing w720p HD call.
However of course if less motion in transmit image, it still capable for sending w720p at 512kbps call.
Thank you Taniguchi-san,
We could connect from SX20 to MCU at 512kbps with HD quality by changing some settings of them.
We understand the HD resolution at low bandwidth causes bad user experience but our customer wanted to know if it was realizable or not.
Of course we have informed them that this configuration is not recommended.
Best Regards,
Kotaro
Great to hear that you managed to establish 720p call at 512kbps now by modifying the configuration.
Please note, as I mention earlier if less motion on video (i.e live stream of Japanese chess/chess match), 720p call is capable even with 512kbps.
Acceptance level of video quality is very depending of actual user so best approach is to actual customer to decide what video format is best/reasonable for their conference style.
Just other thought, if customer really what to have 720p on main video but has the bandwidth limitation on their production network, probably customer may force to use G722.1 on audio protocol (uncheck other audio protocol on MCU setting).
Of course this will lower the audio quality compare to using AAC-LD, however this will allocate approximate additional 30-40kbps to main video channel instead of 448 kbps while 64kbps allocated on audio channel because G722.1 require less bandwidth allocation.
Hi Taniguchi-san,
Thank you for your information.
We will try that if needed.
Best Regards,
Kotaro
