Help for VCS Replacement
FERTHOFELES
Hi!
A client has request a VCS solution in order to make a video conference between 3 or more endpoints like jabber client or any telepresence endpoint.
I was wondering if I could use Expressway - E and -C to make it possible, please if anyone can get me a hand on this.
Thanks in advanced,
Best Regards
Then you're looking for CMS if you want video conferences.
java
if this helps, please rate
Jaime Valencia
VCS is not a conferencing system, I would strongly suggest you approach a local Cisco partner with UC specializations to discuss your requirements and needs, and then they can propose a solution with that info.
java
As a matter of fact, there is already an CUCM, IM server, jabber, the version is 8.5 and plan to migrate to 11.5 but the issue is to make a videoconference
java
