How can I add a hosts address to an expressway server?
John Huthmaker
Level 4
Level 4
I have a unique scenario with a client.  They are using an expressway-e with dual nics.  They do not have a real DMZ, so the Expressway-E is just in a separate VLAN.  We were unable to get video working with a single nic, so Cisco told us to use dual nics.  That resolved B2B calling.  However, I cannot get MRA working.  The MRA zone has to point to the second nic of a dual nic Expressway.  Since DNS does not point to that IP Address, it fails every time.
I can think of two ways to fix it.
1) Add the second IP Address as an alias in the SSL Certificate on the Expressway-E
2) Create a hosts file that points to the second IP Address of the Expressway-E on the Expressway-C
Does anyone know how to do the second one?  Does anyone know if the first one would work?
Oleg Serstjuk
If you're getting public CA to sign E cert it wont accept the IP address
This works to get TLS working and the records survive a reboot of the expressway
https://cdpneighbors.com/spoof-dns-on-expressway/
login as root
For static A records, create a file called hosts.conf
/tandberg/etc/dnsmasq.conf.d/hosts.conf
address=/expe-mra.car.pnslabs.com/10.20.30.40
For static SRV records, create a file called srv.conf
/tandberg/etc/dnsmasq.conf.d/srv.conf
srv-host=_cisco-uds._tcp.car.pnslabs.com.,cucm.car.pnslabs.com.,8443,100,0
After adding the file, you’ll need to restart dnsmasq: - I couldn't get this command to work so rebooting the expressway did the trick
/etc/init.d/dnsmasq restart
